Lowering the blade on a walk behind
Rickcin
I just started using an eXmak 36 inch Metro and I was wondering how to lower the blades a quarter or half inch and if it is a big deal ?
I can see the blade shafts are exposed, stick up through the pulley cover plate and looks like they have washers under the nuts.
You raise Or lower the mower deck by moving Front Wheel spacers above or below their mounting bracket.... You can use the spacers provided OR go to a hardware store and get thinner spacers, to allow a smaller movement Up or Down... :smile:KennyV
