joe's mobility
- Aug 28, 2013
- 1
The JD LA130 I took in on a trade seems to run and cut perfectly until I try to go up an incline...very low power and speed. Is this common with the 100 series as one other user has indicated? Does the transmission require oiling...If so, could this be my problem? I have had the belt replaced thinking that, although it was recently replaced, It may have had the wrong size put on..made no difference....any solutions?
