Engine Looking for Replacement Crankshaft for GCV160 Engine
Gaut1578
My wife was cutting the grass and ran over a man hole cover in our yard. Needless to say the cover won and bent the shaft on my mower. I am looking at replacing the shaft but having trouble locating the part. Every site i go to does not have my engine model so I do not know what part number I need to order.
Honda Lawn Mower
Model # HRR216VKA
Engine GCV160A0 MX1 R280
Serial# GJAPA 1757343
MX1 R280
I was on this website in a different forum, someone said the part number was 13310-ZM0-640. I need to order this part asap, cause my grass is getting high and I have to cut it.
Thanks
mechanic mark
robert@honda
Thanks
That's probably correct, but let's have the MOWER serial number off the back of the mower deck:
"MZCG-1234567"
mechanic mark
"MZCG-1234567"
Thanks Robert for your expertise, hope your recovery is going well!
robert@honda
All good, thanks for the kind words sir. I opted for the extended warranty, so what could go wrong? (ha-ha-ha). :laughing:
Does the e x t e n d e d warranty on your back job mean you are now taller ?
Good to hear things went well.
Gaut1578
Ok the Serial number is MZCG - 8552168
Model - HRR2168VKA
Engine - GCV160A0 MX1R280
GJAPA 1757343
Everytime I try to find the engine GJAPA I can not find it. They have GJARA, or AAA and so on but not GJAPA.
Gaut1578
Well you have to take the engine apart to fit it so why not do it now.
It is prudent to pull down the motor first.
Chances are there might be other damage inside the engine so at best you then have to order more new parts or at worst the engine is damaged beyond repair
