Lombardini
- Mar 3, 2014
- 3
- 8
Hello everyone i have a 26 year old Lombardini IH 218 intermotor gas engine with some problems.
The carb was full of moisture and water and all that bad stuff but i tore the carb apart and cleaned every single thing thats on it.
But (stupid me!) When reassembling the thing i forgot to take the 2 rings away to screw the carb onto the engine again.
So the 2 rings where in the way but i didnt see so there was some space between the intake manifold and the carb.
So i was happy that everything was tight and good on its place and i started it and it was on low throttle but when i started it it was running on high throttle because it was getting false air. But i just was letting it run because i was happy that i got it running.
But i mentioned that there was space between the carb and the intake manifold so i took it of again and i saw the rings and took them off.
So i putted it back together and tried to start it again but it didnt want to i just kept triing until it gave some life but it fell off again.
So i was telling the whole story to my buddy and he said maybe the valves got damaged because it was running at high RPM when it kept getting valse air.
So i was like no it cant be but i wasnt sure so i figured out that you guys here maybe could help me out.
Its not that i dont know anything about small and big engines because i know a lot about them but i just wanted to ask you guys before i am pulling the head off and all that fun stuff.
So if you guys want to help me out id appericiate it.
Thanks Lombardini
Thanks Lombardini
