Lombardini engine problem
westwoodman123
I have a lombardini engine (joker bought lombardini) that has a problem. When I go to start the engine, press the decompression lever in and turn over the engine but it doesn't start. There is no smoke or nothing. What's wrong. The engine is a model lombardini 6ld400/v
I would bet that you are not getting fuel. so bad injector, air in the fuel system, bad injection pump. fuel shutoff not working preventing injection pump from pumping.
