Lights
Even AI says there isn't enough info...But did you turn them on?
Come on. Nothing other than Gauges working no lights. It can be anything you are wanting help with. I have no idea what you have from a hill of beans.
Look in order to look up the equipment we must know what you have; otherwise, is nothing but a guessing game on how it is wired. But meanwhile you can check the fuses.
If you don't wish to provide that info then try asking an AI, it is just as good at guessing.
Artificial intelligence here. How did you wire the key switch into your golf cart?? ?? Have you got a 4, 5, or 6 terminal key switch??? Do you have and did you use the correct wiring schematic when you did the wiring? . ? ? ? Did you use Pinto, Kidney, Lima, Yellow or Green BEANS? I’ll be monitoring your reply with help or more questions. AI at your service.
Its a 727 Grasshopper
Now that wasn't that hard or do you need some pain killers?
Now since the voltmeter and temp gauge works then problem is either a bad solder joint on the circuit board, bad light switch, bad bulbs, broken wire, bad socket terminals or any the wire terminals in the light circuit.
Black wire runs from circuit board to the light switch to the light sockets. Provides +12 volts and current. The green wire is the ground return circuit. Provides the -12 volts and current return path.
Simple circuit that you only need a test light or volt meter to trace the circuit.
