LGT24K54: Drag Links Loose and Hitting Deck Belt Pulley
For bending drag links I use the same 48" shifter I use for bending deck skirts back out
Slide the hole at the handle end over the drag link
And yes a like Pecks anchovie paste ( did you get that in the US ? ) a little bit goes a looooog way
These are new drag links and I do NOT want to remove them again because it wasn't fun getting the steering gear end apart. It is not a bunch out of alignment but I just thought if I could tweak it a bit with the aid of a oxygen/acetylene torch, I could improve it.
