lawn mower fanatic
Depends how much you would use the vacuum feature. I think for the most part i would just be using it as a blower. I would only use it to suck up leaves around bushes. Not sure which one i will get. I will probably buy it sometime this winter so i will look at both at a store and see what I like.
Yeah, just like you, I would be using it primarily as a blower, but would use it as the Shred 'N' Vac some. But in that other thread, it sounds like you have to but different parts in it to make it the Shred 'N' Vac, and it would be louder, which means it would also be louder when it was being used as the blower (unless you switched like 5 parts every time you switched uses!), and that is what I liked about the blower--it was quite. :confused3:
