sectlandscaping
Ok I had a leak between the housing and seal. I put thread locker on it and put it back together. Now it only drives in circles?
Its possible... When the leak stopped I never opened it. I had the ztr in my garage for a few weeks. When I went to move it back to shed, found this out. If thats the case how would I clean it out? I dont think brake cleaner work, maybe acetone?Did you get it on a shaft or at the case side of the seal?...
Also most thread lockers 'wick' into very small spaces... you don't want that stuff anywhere around small passages or valves.. KennyV
