Bessy...
rekees may be right... (hopefully not on BOTH counts) :laughing::laughing:
REMOVE the spark plug, lay mower on its side and slowly rotate the blade, you should be able to see if the shaft is bent... also check if it is leaking oil at the seal where the shaft exits the engine.
Where is it leaking gas? KennyV
