Leaf Blower Won't Run
AdamE
Hi all, I've got a Husqvarna 125B leaf blower that just won't run. I can start it on full choke and it will respond throttle inputs and of course some smoke.
If I move it to partial choke (warm up), it responds less to the throttle and also smokes a bit less. But, when I move the choke to normal, it smokes worse, does not respond to throttle and finally dies after several seconds unless I choke it again.
I pulled and disassembled the carb. Checked the diaphragm and needle. And, I dowsed it in carb cleaner. The fuel and air filters looks fine. The spark arrestor is clean.
I put it all back together and it's the same.
Any thoughts?
Nope,
What you posted makes no sense so a full diagnostic would be the way I would go.
Easy bit first , new plug.
After that loosen the fuel cap
After that loosen the muffler
let us know what happens.
