Lazy Boy 3 Small Tiller
Franken-Roper
Ok here is another question, I have a Lazy Boy 3 Tiller with a 3.5 HP Techumpseh engine. My problem is when I start it up it will run fine and when it gets warmed up it quits and will not start again till its cold again. What do I do to fix this problem?SE2.jpg
The tiller in front is the Lazy Boy. Thanks for the help
Probably going to have to replace the coil. Sounds like it is shorting out when it gets hot.
