OK - so I'll ask the moronic question.
How do you change the rear tire on a Lazer HP? I am a homeowner, which mean I do not own a floor jack, jack stands, or a fancy pants zero turn lifting jack.
What I do have is my car scissor jack, and some blocking. Can I loosen the lugs, put my car jack under the frame, jack it up a couple of inches, remove the wheel, and block it until I get the tire fixed?
The tire has a slow leak - three days to go flat. What is the correct tube to put in? It's a 24x9.5-12 Carlisle tire, with no obvious punctures.
And while I'm acting stupid, the guy I bought the mower from had this tire installed with the outer lettering facing in. I guess tires have a tread direction, so this should be changed - correct? Any local automobile garage with a tire changer can do this - right?
Thanks,
Thanks,
