I just picked up a 10422 that I plan to clean up and use. I removed the engine from the deck which leads me to my first question.
1. Are all three holes (mounting location) where the engine attaches to the deck supposed to be raised or domed? As you can see in the picture one isn't like the others and I assume that deck bolt was loose causing the vibrations to wear down the deck over time. I'll probably JB weld a washer to that area and paint over it.
2. This is my first time seeing a plastic carb on an F series LB. Are there supposed to be two plastic collars to cover both holes on the air filter box?
Thanks,
Thanks,
