22R
- May 16, 2013
- Threads
- 11
- 42
I have a model 10515 that has become hard to get started. I changed the plug and cleaned the carb. If I prime it with WD-40 I can get it started and it runs pretty good. When I let it sit I choke it and it will pop and try put can't get enough fuel seems like. I have drained tank and replaced the line and the choke mechanism is closing fine. It has stopped while cutting and I can't get it started without priming but usually stays running as long as I want so I don't think the coil is the problem. It has the metal walbro carb. Gotta be something simple just kinda new to Lawnboys and aggravating to have so much starting trouble with something so simple.....or maybe not. Any advice appreciated.
22R
22R
