Lawnboy 10415 help
22R
I have a model 10515 that has become hard to get started. I changed the plug and cleaned the carb. If I prime it with WD-40 I can get it started and it runs pretty good. When I let it sit I choke it and it will pop and try put can't get enough fuel seems like. I have drained tank and replaced the line and the choke mechanism is closing fine. It has stopped while cutting and I can't get it started without priming but usually stays running as long as I want so I don't think the coil is the problem. It has the metal walbro carb. Gotta be something simple just kinda new to Lawnboys and aggravating to have so much starting trouble with something so simple.....or maybe not. Any advice appreciated.
22R
BlazNT
Dirty carb, air filter or fuel filter. Compressed air for the little holes in the carb. Im betting carb.
22R
Thank you for the reply. air filter is new, fuel screen filter is clean and I took carb apart and blew carb cleaner and then compressed air thru each passage. What boggles my mind is that it runs well once I prime it but it just won't draw enough gas on choke to get it going. I guess I missed something but I have an extra carb so maybe I will clean and try it.
22R
LB8210
You need to replace the top and bottom crank seals. Leaking seals let in air on the suction side of the piston compression stroke. This leans out the fuel air mixture.
BlazNT
Not saying the seals don't need to be changed but the rest of that is not true. Rings keep stuff from the crank case out of the combustion chamber.
LB8210
Air that is sucked by leaking seals into the crankcase leans out the fuel air mixture in the crankcase. This lean mixture is then routed through the transfer port to the top side of the piston to be burned in the combustion chamber. The rings have nothing to do with the path the fuel air mixture travels through the carb past the reeds to the crankcase through the transfer port to the combustion chamber on the top side of the piston to be burned.
Phototone
Tighter rings increase the suction and transfer of fuel, but leaky seals will still mean a "too lean" mixture.
LB8210
As I said before the rings have nothing to do with the PATH of the fuel /air mixture. His problem is not caused by poor compression, ring sealing.
22R
I think that we may have a winner. upon further inspection I found the bottom seal down around the shaft away from the bearing where it should be. I have ordered two new ones. After I remove the flywheel do I have to take apart the housing to get the top one out or can I just pop it out in place to change it ? The bottom one being out I suppose that I can just caress the new one back in ??
Hopefully this will get me straight. Appreciate all the replies gentlemen.
22R
LB8210
You should be able to replace both without opening the crankcase.
