Need a little more advice on the above.
I had a hard time starting it, but cleaned carburetor, new plug, clean filter, and it starts after priming it 3-4 times.
I cut the front yard today, and ran really good, no poblem at all. However, after it starts and runs, it will not start, without priming again after cutting my whole yard, and engine is very hot.
Someone suggested before top and bottom oil seals. If I replaced these, do you think that would take care my problem? Many thanks.
