I have a Lawnboy 10343, Green Series, 4.0 HP, SP, that runs very good. The coil had not been changed in many years, and I replaced it this year. It starts on 1 pull, every time.
However, when I do get it going now, IT WONT CUT OFF when I release the brake bale. I had thought maybe the wire from the ignition to the brake plate needed replacing, and I did that. However, it still wont cut off. Could it be some other problem than the brake system? Thanks very much.
Ed
Ed
