lawn tractor blades stopped turning
mikeyT
Hi,
I have a Craftsman YT3000 and I hit a log with it and then the blades started making a funny noise so I stopped the mower and had a look. The blades looked fine and all of the belts looked good. I was able to manually turn both of the blades using the cog that comes from the engine.
Then I started mowing again and while it sounded a little funny, it was mowing okay. Then the blades started to sputter and then they both stopped. Anyone have an idea of what could be wrong?
Thank you
mechanic mark
remove deck & inspect all parts topside & underside, belts, blades, pulleys, hardware, etc. let us know what you find, thanks.
