Forget an extension, it won't live. Your best bet is a power washer engine.
R Romore Well-Known Member Joined Jan 19, 2019 Threads 1 Messages 260 Nov 8, 2019 / Lawn Mower to Log splitter #21 Forget an extension, it won't live. Your best bet is a power washer engine.
Scrubcadet10 Moderator Staff member Joined Sep 24, 2017 Threads 250 Messages 6,437 Nov 8, 2019 / Lawn Mower to Log splitter #22 I've got a Honda gcv160 off of a troy bilt pressure washer, low hours, the pump froze. If you're interested. If it will fit.
L Leever2000 Member Joined Sep 7, 2014 Threads 5 Messages 48 Nov 9, 2019 / Lawn Mower to Log splitter #23 My replacement engine is a pressure washer engine, but the shaft is about 1.5 inches too short.
cpurvis Lawn Addict Joined Aug 25, 2015 Threads 21 Messages 2,256 Nov 9, 2019 / Lawn Mower to Log splitter #24 Can you add a pair of Lovejoy couplings?
L Leever2000 Member Joined Sep 7, 2014 Threads 5 Messages 48 Nov 10, 2019 / Lawn Mower to Log splitter #25 can you show me an example?
cpurvis Lawn Addict Joined Aug 25, 2015 Threads 21 Messages 2,256 Nov 10, 2019 / Lawn Mower to Log splitter #26 https://www.lovejoy-inc.com/products/jaw-type-couplings/l-type-standard-jaw-coupling/
L Leever2000 Member Joined Sep 7, 2014 Threads 5 Messages 48 Nov 16, 2019 / Lawn Mower to Log splitter #27 Is there a way to lengthen the shaft? The replacement engine has a shaft that is 1 3/8 inches shorter. Is there a way to use this engine with a shorter shaft?
cpurvis Lawn Addict Joined Aug 25, 2015 Threads 21 Messages 2,256 Nov 16, 2019 / Lawn Mower to Log splitter #28 Why won't the Lovejoy coupling work?
L Leever2000 Member Joined Sep 7, 2014 Threads 5 Messages 48 Nov 16, 2019 / Lawn Mower to Log splitter #29 Is there a lovejoy coupling that will lengthen the shaft?
cpurvis Lawn Addict Joined Aug 25, 2015 Threads 21 Messages 2,256 Nov 16, 2019 / Lawn Mower to Log splitter #30 Leever2000 said: Is there a lovejoy coupling that will lengthen the shaft? Click to expand... Take a look at the photo. Lengthening shafts is not their intended purpose but in your case it's a fringe benefit. CALL Lovejoy and ask them if they make a coupling that will solve your problem.
