jes_in_sac
I got tired of the worthless Lawn and Garden lead acid batteries. I've been using ATV/Motorcycle AGM sealed batteries, and they are much more durable, particularly on the rough acreage I run my mower over. And they are cheaper online, with no core charges. For the same amps, they will usually be a little smaller, so I just fill the gap with some foam packing material, which even further cushions them. And yes, definitely keep a battery tender on it... summer and winter. All of my batteries on the farm have a battery maintainer on them. You can even buy them in multiples for cheap online. I have a solar powered one on my dump trailer. Batteries have gotten expensive, and most of them "lightened up" [less lead], so it helps to keep them maintained to last as long as possible and a maintainer helps keep them from sulfation [clogging up internally] when they just sit there.
