lawn boy 8241AE electric start
jonf6
8241AE electric start QUESTION
would like to know if i can put a pull start cup on this machine
this model come just with electric start No puller
if so does anyone know the part number for this part ??
lawn boy 8241AE
lewb
If there are provisions for a pull start you may be able to do it. Got to think that it would be cost effective to use the same mold instead of using a mold for one model. You will probably have to tap the holes if they are there. If this is the case I think it can be done. Parts tree do list the parts, but you could buy a donor mower for much less when you add up all the parts needed.
https://www.partstree.com/parts/law...c00000001-c99999999/engine-group-models-8241/
If you want to just throw another f-motor on your deck there is a guy from out east that bought several f motors rebuilt that have tank, carb where all you would have to do is mount to deck and run some cables. His wife has a youtube account named "cat Lady".
Good luck.
Dual start or pull start only engines have longer crankshafts for the starter mechanism to engage with.
Asimilar question was asked a few days ago and some one came in with part numbers.
