Lavor thermic 3/s pressure washer (tecumseh vantage 35 engine) rpm
blithering
  • / Lavor thermic 3/s pressure washer (tecumseh vantage 35 engine) rpm
Does anybody know what rpm this model should run at for the maximum quoted running pressure?
Mine chugs along but the pressure is not up to par.
I can raise the revs using at the governor lever if necessary.
Apparently this information is on microfiche card # 30 - is this available anywhere to view under a different format?
We could use the model and spec numbers to help us out, but without them I’m going to guess you have a model HSK35 engine. If I’m right No Load Top Governed Speed would be between 3300-3450 RPMs. The thing that confuses me is why a SnowKing engine would be on a pressure washer?
blithering
It used have a sticker logo on the cowl which I think said vantage 35, it fell off some time ago.
On the side there is a sticker - VAN 148 E6267E also S4077A
It is a vertical engine
Here is a photo of one but not mine but it is more or less the same
I now is theproblem I’m having finding a manual for that engine as it is a Tecumseh engine manufactured for Europe. I’m guessing that it is equivalent to the engine I posted earlier, so unless you can find specs on the European model I would go with the RPMs I posted.
sgkent
numbers depend on the pump and engine combination. My 1998ish Craftsman / Generac 4hp runs at 3200 RPM loaded and 3550 no load. 1750 PSI 2.0 GPM.
blithering
That's useful information in the absense of a manual for my machine
