Landlord series Deck Lift Issue
ollieboy
I have an older Landlord series mower, and the deck lift doesn't work ( I just bought it ). I took it apart, and the motor will run, and the screw will extend or retract to the max limit in either direction, but will then jam. With it on my bench I can easily unjam it at then change the travel direction, but not easy on the tractor. With the cover off it, it looks to me like there is wear on the metal plate attached to the plastic screw gear. I've tried to find a parts list for this Thomson Saginaw lift, but have been unsuccessful. Trying to find a replacement lift unit has also been fruitless. Does anyone have any suggestions?
