LA 145 Vibrates bad!
My 2012 la 145 has suddenly started to vibrate, weather the blades are not even engaged. Sure would appreciate some advice.
Thanks,
Charlie
Check to see if it vibrates badly with the clutch / brake pedal fully depressed
Yes = engine problem
No = Drive problem
If yes, remover the drive belt & try again
Still vibrates all the time = major engine problem
Only vibrates at start up & shut down = loose mounting bolts.
Drive problems
Lump broken out of belt
Something stuck in a pulley
Broken or cracked pulley
idler pulley bearing broken
Tensioning arm pivot worn excessively .
MowLife
No = Drive problem
Drive problems
That is a darn good answer....worded well
No = Drive problem
Drive problems
YOU GUYS ARE MY HEROES. TRIED TEST..NO VIBRATION... REMOVED BELT...BIG CHUNK MISSING..QUICK TRIP TO HOME DEPOT..TADA! MY WIFE IS MOWING AGAIN!
tom3
Another satisfied customer. Now if I could just get my wife on "her lawnmower".
