So I got this mower and it need some work. Got it running replaced steering, rebuilt carb, new filters among other things. Mowed great for a while then it started hesitating and losing power. Checked fuel lines and such and replaced fuel filter, cleaned tank seemed to work. Pulled carb apart again to check needle valve and it's fine. When I put back on it started up but was running so rich it barely ran and when I turned key off it started running perfectly, better than ever before. I messed with it a bit but finally started it, turned key off drove it around and tried PTO but no activation, no electric to it. When key went on motor ran like crap again but PTO engaged and almost killed engine. I am stumped with this, have no idea what the issue is but it appears electrical to me. Any thoughts?? Help is appreciated.
