C ccl088 Forum Newbie Joined Sep 22, 2017 Messages 6 Oct 13, 2017 #21 It does that when you release the PTO lever and the belt flops around for a few seconds and eventually wears thru.
Boudreaux In Eunice La. Lawn Addict Joined Jul 22, 2017 Messages 2,154 Oct 13, 2017 #22 Bill and CC are correct. I have never seen it happen cause I have not seen a guard on the right side of the deck. I just got on here had to make 2 house calls and go to my buddy's machine shop to use his mill to take a broken bolt out.
C CajunMan89 Active Member Joined Feb 28, 2014 Messages 83 Oct 14, 2017 #23 I adjusted the breaks so that the belt only turns for about a second after the blades are turned off, not long after I bought it. Is it just gonna be one of those things where I'll have to replace the guards every so often?
