I have a Kubota with a kohler CH20 twin cyl. horizontal with 1300 hrs. It's been a great mower. Started bogging down under a load and had a pretty bad oil leak. Had to remove the motor to change coils and crankshaft main seal. Cleaned up and found another oil leak at oil cooler. Back together started right up. 15 to 20 minutes into cutting started bogging down again.
I noticed an oil leak on left valve cover. Did a compression check. Both cylinders read a perfect 155 psi. I'm thinking it may be the breather. Any suggestions would be appreciated.
