workinallthetime
- Aug 11, 2014
- 1
- 2
i have a zd326p 60" deck bought new less than 400 hours now
when i mow on a across a slope the down side cuts a inch or so lower then the high side, this is driving me nuts!! the problem seems to be getting worse and worse as the hours rack on. when i mow on flat ground the cut is perfect, i have leveled the blades and put 1/4" rake from fron to rear on them. the guy at the dealer said that is the downside of a full floating deck but i find this hard to be trus since i did not have this issue until the end of last summer.
I have tried pulling the scalper wheels to spec but that really makes the problem worse, right now i have the scalpers dancing across the ground.
any help will be apreciated, i love my kubota's but this is something that has me wanting to move to another brand:confused2:
