kt725-3012 throttle linkage,choke linkage rod position
dandy2960
  • / kt725-3012 throttle linkage,choke linkage rod position
took carburetor off about a year ago and do not remember witch hole the linkage rods go in at the bottom one being for the governor the other is throttle cable i would appreciate any help i can get
fixit1ddh
I can take pic of my 735- 3013 if Yours has single lever throttle choke lever. I would say they are setup in the same holes on linkage.
dandy2960
Yes please thank you I really appreciate you taking the time to do this
VegetiveSteam
Look closely at the holes for any sign of wear. Often the hole can tell you there used to be something in it. It may be as simple as the edges around one hole are slightly shiny where the other are not. Just a thought.
fixit1ddh
