Hey all! First time posting.
I have a Cub Cadet with a Kohler courage 22Hp Model PS-SV715-3027 V-Twin The 2 coils that were on it had that smell of burning electrical so I purchased 2 new coils and installed them. The problem is If I unplug the kill wire from both coils it will run like a new engine. If i plug in the kill wire to both coils it won't start. I went ahead and made another kill wire so it wasn't connected to the system just so I could shut it down after i get it started but even with the kill wire connected to both coils and the end not grounded it still wouldn't crank. even though the coils were kill wire connected and nothing else it still wouldn't crank but then I pull it off and it cranks right up. I made a separate kill wire for each coil only connected to the coils not anything else and it cranked right up if I touch them together it backfires and acts up but I can ground them separately to kill the engine. Why is it I can't connect the coils to the original kill wire and crank or shut down the engine. Can someone tell me if this may have had CDI before it came to me or why its burning coils? Just so you know the original coils did the same thing wouldn't crank with the kill wire on. Thanks for any kind of help! This has been a nightmare!!! Just so you know I had tested and replaced all the switches and key switch but no change. I had all that in stock and used it as a test but no change and checked them all with my multi-meter as well. Thanks jkasza1 The serial number is SN- 4229304833 I forgot to give you this Thanks
