Weezer7211
- May 19, 2018
- 6
Hello all,
I have a kohler CV15S/41525 engine that seems to not be charging my battery. I believe the stator has something to do with it.
I will charge up the battery manually, and the mower will die, and not start back up.
The added problem with this is that there isn't a diode, or regulator/rectifier in this model. I don't understand how it would be safe to charge my battery if everything was fine.
When I charge up the battery, and hook everything back up, the stator starts to smoke, and I know that's not normal.
I'm not sure where to go from here, or what parts i need. All parts diagrams for this model do not have a regulator/rectifier listed, and same for a diode.
Any advice would be great,
Thanks!
Thanks!
