Kohler K series engines
horsesaver
I have a brand new K181 short motor and one of my W/H Raiders needs a revived engine. All my Raiders have 12hp or 16hp. Does anyone know if I can rebore a K181 block to 10hp ( or even 12hp)? Maybee I need a shorter con rod as well????
K181 (8hp) bore size is 2.938. K241 (10hp) bore size is 3.251. K301 (12hp) bore size is 3.375. As you can see there is over .25" difference which will be to large to rebore the K181 block.
horsesaver
Thanks for reply....do you know if I can keep the stroke the same or will I need a shorter con rod?
horsesaver
Sorry misread your response...... it's a no goer.
Regards Neal
