Kohler engine backfire through carb
Jstinson
I have a cub cadet with a Kohler engine it is back firing through carb any and all help will be appreciated thanks jeff
Mikel1
I would check the flywheel key first. If that is good then check valves. Not sure what Kohler you have.
Catherine
LawnWorld Support
Hi and welcome to the forum! :welcome:
I'm moving your thread over to the Cub Cadet section to see if we can get you some more input on that problem.
Jstinson
its a kohler commander is all I know took it off and put oil seals in front and rear it cranked up when I put it back on the frame then quit now all it does is backfire through the carb im stumped
Improperly torqued flywheel causing shearing of the flywheel key. Pretty common problem.
