Kohler CV740-3119 Oil Leak
PhilZ
How to find a oil leak on this mower? The sudden will leak happened after I change the oil filter.
If it has an oil cooler sometimes the bolt that tighten it down which is also the same bolt that filter screws onto will come loose when the filter is removed. Also make sure the oil cooler lines are not leaking. If disturbed from there original location will leak.
