Hammermechanicman
- Jan 10, 2020
- Threads
- 69
- 3,907
That schematic shows the convention ignition not the ASAM ignition you have. Yours will feed 12v to the fuel solenoid and ignition directly from the ignition switch or from a relay. I have seen both on craftsman mowers. Does the fuel solenoid click when you turn the key? Check the connector on the back of the ignition switch for corrosion.
