- Sep 5, 2014
- 5,172
Does a NYLON Gear on cam sound like a good choice for longevity ? Thanks for any advice & input.
The Confidant is a fairly new Engine from Kohler, announced on Oct 21, 2013 to be ready for 2014 & up.
Kohler Engines introduces its Confidant engine series. This vertical-shaft, V-twin engine line was carefully designed to meet the unique needs of both commercial equipment users and property owners.
- Encompasses four models ranging from 19 to 25 hp
- Includes cast-iron cylinder liner to protect the engine in extreme operating conditions, dual-seal air filter to keep debris out of the engine; and high-torque inertia drive started with extra-large output for quick, reliable starting
- Pressure lubrication keeps critical parts protected
- Features Kohler’s PRO Performance Filtration package, a heavy-duty professional filtration bundle that includes a 3,500 cm[SUP]2[/SUP] air filter, a 6.5 gram oil filter, and a 9-12 micron fuel filter
- Includes Quiet Cam technology which consists of a rounded cam lobe and solid nylon gear that work together to help reduce sound levels
