Kohler CH740 power issues.
The difference in the compression is not too bad. Suggest you back off both rockers on each head. Make spark plug threads to compressed air fitting. Put compressed air to a cylinder, valves will be shut since you backed off the rockers. You can hear where the air is going. Intake?exhaust? crankcase?.
