i have a toro model #74240 14 year old 62" mower that has stopped charging, with the mower running full speed i only get .778 volts from the stator. so i assume the stator is bad or the magnets have come loose if in fact that is posable on this model ? do i have to remove the engine to get to the stator ? it has a shaft coming from the stator end of the motor does the fly wheel still press on ?
klein
klein
