Befuttled
- Mar 21, 2021
- 1
- 1
hello I’ve read numerous threads over the years in regards to same problem crankcase pressure oil up in air cleaner area has anyone have a distinct answer my was blowing out vent tube so removed it and vented outside soon later it began smoking so pulled head off clear burnt path to the oil galley problem solved right well upon initial start up ran no more oil up in breather air blowing out oil fill tube when running so fast forward 2 years it’s starting again I do you elimate breather reed blow by I will be looking at head gasket again but with new gasket a lot of crankcase pressure any help as always appreciated
