larryhughes
Kohler 22HP ran hot due to build up of grass under blower housing. Attemped to remove for cleaning but could not remove housing completely although did manage to clean fairly well with prods, etc. Now, after putting back together and running 15 minutes, right side is not firing, so assume is ignition module or loose wire.
What is the secret to removing the blower housing without removing the engine. Surely there is a way. Shop manuals says remove side baffles, but so far have not figured what that is. Any help will be thoroughy appreciated.
