bountyhunter
- Sep 4, 2015
- 4
I'm working on a model k301 12 hp cast iron engine
it seems slow on throttle response takes like 5 seconds + to go from idle to full top rpm on governor
also in side air cleaner it's has black film and making a lot of noise out carb when you open it up
i cleaned the carb and it doesn't flood anywhere
but It runs best at idle with idle mixture screw all the way in
the main adjust as normal any idea were to start looking for problem
or are the Kohlers always a little lazy throttle response wise
Thanks Ferris
Thanks Ferris
