Koher PRO 16 OHV, Model#CV16S, SPEC#43527 NO SPARK..
kartking
had spark but lost it....
tried new spark plug ..still doesn't work
do u think i should try replacing the coil?
It looks like your engine has the DSAI spark advance ignition system. So that little box could also be your issue, as well as a bad wire connection that supplies power for the system to work.
kartking
Thanks for the info
i just dl the manual today and read how to check that "little black box"...
i hope it tests ok cause its not a cheap part...
a broken wire would be nice to find instead :)
