I bought this powerhead with a edger and hedger attachment approximately one year ago. From the first day I had it, it did not run correctly. The symptoms are, even after the engine is slightly warmed up, when you hit the throttle, it falls on its face. This occurs even if it’s been run throughout the day. Confirming to me that it is not a cold engine issue. I’m assuming it’s just a carburetor problem. Basically, the low end on the throttle seems to be having a problem. Routinely when you hit the throttle, it falls on its face or stalls, and even sometimes acts as though it is flooded. Again, this is from since the unit was brand new. Anyone have any ideas or experience this themselves? If so, can you purchase the tool to adjust the carburetor, or do you have to take it to a shop?. Thanks, Scott.
