Kelvar belts
Kelvar belts are generally used when you have a back side idler pulley... They will hold up to that type of wear a lot better than a regular belt...
Also if you are breaking your belts from shock at start up you may get more time from them than you do with regular belts...
Have you been breaking belts? :smile:KennyV
Thanks for your reply.. The belts are breaking from time to time due to the odd small twig flying up in to the deck . I will try a couple of Kelvar belts and see how they go.
Ron
