JMACDATHIRD
- Oct 3, 2023
- 2
- 4
Thanks for taking the time to help me, it worked just as you said.It will fine. But before you plug it in close the gap on the terminal on the RH side of the posted image as it will be a loose connection otherwise. And it doesn't matter which way it is inserted as the solenoid will work either way.
