Kabuta T1460 mower belts
JFM
When I try to disengage the blade belt drive the blades keep rotating. I have renewed the arm with the brake pad. And tried numerous adjustments to the cable. Both springs are present.
mechanic mark
Check your owners manual PTO clutch adjustment, you will be adjusting air gap at pto clutch.
mechanic mark
