Hi All,
I managed to pick up a JD LA120 on the cheap because oil was poring out of the RH Tranny shaft....Turns out the shaft spacer had warn straight through the washer (between the wheel spacer and the case) allowing the wheel spacer push into the shaft seal, ripping it open.
The mower was just about moving when I picked it up and when I drained the oil there was about half a quart of oil still in there.
Anyway before I investigate what's happened inside I wondered if anyone could help me with these questions? ....
Many thanks for your help
Neo7
- If a K46 transaxle runs low on oil will it damage itself or just stop running?
- Is there anything that I should closely inspect in there when I open up the case?
- I have a T40J TRANSMISSION (exactly like a K46)..... But what's the "W/FILTER IDS"?
- Is the seal something special that only TT can supply?...Below is a picture of the LH seal that's still Ok.
- Also, does anyone know what the adjuster and locking nut (in the picture below) does?
Neo7
