TnHusky
- Mar 10, 2013
- Threads
- 14
- 127
I'm only doing this so it might help someone make a decision on which mower to buy, so here we go. Last night I mowed my Moms yard while Her and my Sister went to the Funeral Home, they have the L130 48" cut JD with a 21hp briggs engine. (V-Twin) I had recently serviced the engine with new oil, filter and AC and cleaned and greased and sharpened blades so I knew it was ready to go. Now with this being said the mower does have 289 hrs on the clock and is around 4 to 5 yrs old.
The one thing I first noted of course is the speed difference between the two, the Husky wins hands down, such the name of the Fast Mower I guess. :laughing: The front end on the JD is very loose, I mean feels as if something will fall off loose but I checked and I guess it's just wear. The deck seems to cut in the yard a bit more than my Husky does on turning but overall does a decent job on mowing. This mower however has the dreaded button to push when in reverse to keep engine running which is a pain the azz. That would have to go if it were my mower. The sitting position isn't as good as mine, feels sort of like your on top of the mower and not down in the mower if that makes sense but the seat wasn't to bad at all.
Now on to the power, the briggs engine is quiet, I'll give it that and smooth but the power is a lot different than the 24hp of the Kohler. It tends to bogg quiet a bit in taller grass to the point I'd slow down some where as my mower would have breezed through it. The Big Tires leave quiet a Patch where you have mowed verse the Husky as well but overall did ok.
So after I was finished mowing about 2.5 hrs would I buy a JD L130, if the Husqvarna wasn't there I might look at one but overall I like my mower a lot better, power, speed, overall tightness and smooth cut. Now again I know I'm comparing and older mower to a new one but the front end feel didn't feel that bad on my 12 yr old White I had so that bothers me a little. Anywho, sorry for the long write up just my opinion from a regular home owner. Husqvarna wins hands down for me, JD still a good mower but I'd still pick what I did if I could do it all over. I also hope no one gets mad at me doing this, not trying to stir anything just one mans opinion, thanks.
