djdicetn
- Sep 3, 2012
- 2,193
The thing you need to look at is the outside wheel measurement, the EZ takes anything up to like 47 " the Pro goes out to 62" I'm not sure if the wildcat will fit the EZ or not. AS far as the lift goes I agree all the weight is going to be in the back.
Oooops, I plumb forgot that minor technical limitation:0) Thanks Ric!!
But, it looks like your Wildcat is a 52" deck so I wouldn't think the front wheelbase would be that much more than my 52" Gravely......but would recommend you measure it before buying the MoJack EZ model to be sure it would work:0)
